Yamaha TDR 125 2000 - Derestricting
Re: Yamaha TDR 125 2000 - Derestricting
Messagede phifi le 28 Juin 2012 21:53
It does not mount on the TDR, it does not pass to the frame.
Your bike is over 9500/10000 RPM when you push the speeds?
Messagede TDRider le 29 Juin 2012 8:47
It gives it max at about 7000 rpm.
I looked German forums and they aro talking about electronicaly restrictions which move spark angle when the bike reach 7000 rpm, but I couldn't find wich wires do I need to cut, does anyone know something about that?
Thanks!
TDRider
Motos: Yamaha TDR 125
Messagede TDRider le 19 Juil 2012 15:05
Today I was asked one guy who have older derestricted TDR to borrow me it's electronic, so that I finally can see is problem in it, and it was.
So I'm looking for new CDI, and I want to ask does it fits from all models, including older Belgrada model?
Thanks!
EDIT:
My CDI have 16 wires!
TDRider
Messagede phifi le 19 Juil 2012 15:23
Messagede TDRider le 19 Juil 2012 16:53
This isn't bad solution if I don't find the used one, but first I want to try with used, probably if I find from some older model, so because of that I won't to know are they compatible.
And also if it fits, does I get more power at high rpm's, because as I heard older TDR's wre powerful than these new?
TDRider
Messagede phifi le 19 Juil 2012 17:34
Make a photo of your cdi and all its connectors
Messagede TDRider le 19 Juil 2012 17:56
TDRider
Messagede phifi le 19 Juil 2012 21:53
Compatible with a french cdi.
Messagede TDRider le 19 Juil 2012 21:58
Hmm...
Do you maybe know is it compatible with Switzerland model, because here are lot's TDR's which are imported from Swiss.
TDRider
Messagede TDRider le 25 Juil 2012 13:51
Here I can get older CDI from Belgrada, which have significant less wires than my, so is there way to connect that older CDI to my bike?
Thanks!
TDRider
Messagede phifi le 26 Juil 2012 1:25
This is not compatible.
Messagede TDRider le 26 Juil 2012 17:17
Is any way to connect CDI from TDR 1997, I think that mark on the CDI is 4gw, it have 12 wires?
TDRider
Messagede TDRider le 26 Juil 2012 17:41
Or can I buy this cdi and the servo and fit that on my bike:
http://www.njuskalo.hr/moto-dijelovi-os ... as-5612719
TDRider
Messagede phifi le 27 Juil 2012 0:05
This cdi is only for TDR from 1993 to 1996.
Messagede TDRider le 31 Juil 2012 17:16
I got an idea to make my own CDI for ignition only, and to leave this so that it can open the valve.
Do you think is that possible?
EDIT:
And do you know does this from DT will fit:
http://www.ebay.com/itm/Yamaha-DT125-R- ... 51a02c60d7
TDRider
