Yamaha TDR 125 2000 - Derestricting
Messagede TDRider le 27 Mai 2012 18:39
Hi all!
First of all, apologize on using English instead of French, but i don't know a word of French, and I have the problem with my TDR, and I tried everywhere and no one helped me. So you are my last chance.
So, I have Yamaha TDR 125, 2000 year, which is bought in Germany. Type is 5AN, and cylinder code is 4FU00, and it's fully stock, so I want to derestrict it.
I know for the power valve restriction, but what's about the exhaust, and are there any other restriction.
I found this picture, on your forum which show where to cut:
http://yam2stroke.free.fr/preparation/m ... ente_1.jpg
Is that proper place to cut on my bike, and are there any other restrictions on my bike!
Thanks a lot!
Fell free to answer on French if you aren't very good in English, and I will use Google translate.
TDRider
Motos: Yamaha TDR 125
Re: Yamaha TDR 125 2000 - Derestricting
Messagede phifi le 27 Mai 2012 19:12
Yes, this is the place where you must cut the exhaust pipe.
Here are photos of the restriction:
Before
After
Messagede TDRider le 27 Mai 2012 19:16
Thanks on the fast answer.
Are there any other restrictions except this, and Power Valve.
I heard that TDR also have the catalyzer, and what about silencer, and inlet manifold, are there any other restrictions?
TDRider
Messagede phifi le 27 Mai 2012 19:23
Pas d'autres restrictions sur les modèles français.
Les versions catalysées ont été fabriquées de 1993 à 1996.
Il existe peut être sur les TDR allemandes une restriction électrique (comme pour les DTR allemandes), mais je n'en suis pas certain.
J'essaierai de me renseigner...
Messagede TDRider le 27 Mai 2012 19:36
In this topic it says that I need to earth black/blue wire:
http://dt125r.activeboard.com/forum.spa ... D=10609464
So that it look's like this:
http://files.activeboard.com/174675?AWS ... JCwDC2M%3D
I done that and I didn't noticed nothig, bike still gives it best at 7000 rpm.
TDRider
Messagede TDRider le 27 Mai 2012 21:37
Also when all restrictions are removed, how much power does it will have?
I heard it's about 28 hp.
Cylinder is 4fu00.
TDRider
Messagede yanidimani le 27 Mai 2012 21:42
Hello
On a TDR there is no electric clamp. Everything is done to the exhaust valve and muffler. Your link is for the DTR, not for TDR!
After you have to adjust the carburetor.
Good luck!
TDRider a écrit:Also when all restrictions are removed, how much power does it will have?
Cylinder is 4fu00.
An engine of 2000 is a 5ae. Entries 4FU were not changed to manufacturing.
For power, I think it is better to expect 25hp max.
To adjust the valve
viewtopic.php?f=26&t=7902
Messagede TDRider le 27 Mai 2012 22:44
yanidimani a écrit:Hello
Good luck!
Hmm, but if the cylinder is the same as the TZR, 4FU00, but 25 hp, also isn't bad, especialy because, tdr have lot's of power in midrange rpm. But.....
Also should i take care of my exaust muffler, are there any restrictions?
Merci!
TDRider
Messagede phifi le 28 Mai 2012 9:12
:lol: TZR's are far from developing 30 horsepower, except in dreams ... on the internet.
:arrow: In your model, the restrictions are:
Exhaust pipe
Powervalve
Cdi (switch in the tachometer)
:arrow: The original CDI has an output of 5 volts, this one goes to the counter by the white / green, and there is a reed switch in the tachometer.
When you start the engine of the bike, the counter restarts from the +5 volts to the motor valve through the green / black.
However this system is not on all versions, it served the same flange on German models by preventing the current flow to the engine valve from 80 km / h ....
If you have this white / green wire coming to the speedometer: you can cut it, or put a switch.
Messagede TDRider le 28 Mai 2012 9:44
OK! I will try to see is there that wire in friday, I can't earlier because of work.
Maybe I have that restriction, because my bike do only about 100-110 km/h.
Can you tell me should I cut silencer, are there any restrictions?
TDRider
Messagede phifi le 28 Mai 2012 9:48
Any restrictions in the muffler...
Messagede TDRider le 28 Mai 2012 9:50
phifi a écrit:Any restrictions in the muffler...
My bad, i thoat is there any restriction in the silencer?
Sorry!
TDRider
Messagede phifi le 28 Mai 2012 10:01
Any restriction in the silencer... The only restriction (for the exhaust pipe) is the "body of the muffler", like the pictures I posted last night.
Messagede TDRider le 28 Mai 2012 10:07
OK!
Great man, you helped me a lot!
I looked everywhere on forums, and nobody knows, and here you give me fast and full directions what to do.
One more time, thanks a lot! :bierre:
TDRider
Messagede love2stroke le 28 Mai 2012 10:57
Yes, yam2stroke is one of the best sources of information on the internet regarding 125 and 200 Yam two stroke motorbikes. =D<
People come for advice from all over the world.
Let it know around you!
And Phifi is a great man, definitely the most knowledgeable member of the forum. [°]
