Compression pressure
Messagede smokieDT125r le 08 Déc 2007 1:12
Hi Does anyone know what the compression should read on a gauge for a std DT125R with powevalve open?
smokieDT125r
Re: Compression pressure
Messagede arno le 08 Déc 2007 8:00
when I've started my engine (with starter,no kick),I've read 8-8.5 bars but at this rpm the powervalve is closed.
I don't know the pression when the power valve is open.
tomorrow,if I've the time I'll see this cause today I'm overbooking
arno
Messagede arno le 09 Déc 2007 12:06
conditions of test,engine cold with reed valve,carb,without airbox
open exhaust valve : 8 bars
the same but without exhaust system : 7.5 bars
my system exhaust is the original with catalyse
arno
Messagede smokieDT125r le 09 Déc 2007 15:27
Merci mon amie . Mine is 8 bar too :D
smokieDT125r
Messagede arno le 09 Déc 2007 18:18
ami,it's better :shock:
arno
Messagede smokieDT125r le 09 Déc 2007 18:52
pardonnez-moi monsieur très désolé :D
smokieDT125r
