Bas Moteur WR200 ?
Bas Moteur WR200 ?
Messagede Mr.Wheely le 22 Mar 2008 19:05
I would like to know if the WR Bas Moteur fits in the DT125? I only know that I can use the 125 Bas Moteur with the Vilebrequin of the DT200 for the WR cylinder, but I would like to assemble the complete Moteur of the WR (Cylinder, BAS Moteur, cdi)
Thanks
regards from Allemagne
Michael
Small Frame - Big Attitude
Mr.Wheely
Re: Bas Moteur WR200 ?
Messagede arno le 22 Mar 2008 20:29
you can use the crankcase of dt 125 with the crankshaft of dt 200,but the diameter of crank mass of 200 is bigger than 125.It's the only difference
So,you must do ajusted in the crankcase of dt 125 (about 2mm)
you can use the wr cylinder.
arno
Messagede Mr.Wheely le 22 Mar 2008 20:48
Hi, I already know that. I want to use the complete WR engine, not only the Cylinder. Does the WR engine fit in the DT125 frame?
Mr.Wheely
Messagede kristian le 23 Mar 2008 1:20
http://yam2stroke.fr/viewtopic.php?f=14&t=10290I think tou get the answer... but it's to be checked.....
