How to plug a TZR 2RH cdi into DTR wiring loom
Messagede yamahaexpert le 10 Fév 2011 13:00
Hi, i'm wondering if someone knows how to plug correctly a TZR cdi ( 2RH model ) that is first TZR model, into a wiring harness loom from DTR first model ( 88 to 99 ) . I took a picture and put a red circle where i have problems to connect. Is that to YPVS servo engine ( 3 wires version ) or to plug directly on wiring harness ?
Thank you very much for your help 8)
yamahaexpert
Motos: DT125R / DT200RW
Re: How to plug a TZR 2RH cdi into DTR wiring loom
Messagede ferrarinero le 10 Fév 2011 14:38
J'vais regarder ça ;) (dsl on est en france donc j'écris en français)
new personnal yamaha 125 ;)
ferrarinero
Motos: yamaha DTR restylée!!
Messagede yamahaexpert le 10 Fév 2011 15:27
ferrarinero a écrit:J'vais regarder ça ;) (dsl on est en france donc j'écris en français)
Thanks mate ! sorry i wrote in english, just to be more easy for i explain my problem but i can understand french so you can reply me in french :wink:
yamahaexpert
Messagede phifi le 10 Fév 2011 16:26
Look at this diagram and you'll have your answer:
You want to connect it on what model of DTR?
88 models have a special wiring, then 89 and 98 is the same.
Messagede yamahaexpert le 10 Fév 2011 18:27
Thanks Phifi, but i also have that diagram and i think it hasn't what i'm really need because i've all original electrical components including the generator and Ypvs servo engine. The bike is a 92 DTR and what i'm looking for is where i should connect the plug with a red circle. I took more pics from generator and ypvs servo engine and they have the same plug with same colors as from Cdi
Here's two pics from generator :
A pic from 3MB DTR Generator and 2RH Cdi together, are they correctly connected ?? :
The YPVS servo also has a plug with these two wires, maybe can be to plug there ?? :
Also in wiring loom there is a plug with same colors, so that's my doubt :
Is there someone who can explain me the right places to connect all the plugs ? Thanks 8)
yamahaexpert
Messagede phifi le 10 Fév 2011 19:12
:arrow: Connection to this picture is correct:
:arrow: the green plug does not fit.
:arrow: These 2 connectors should be connected together.
It's the 12 volts alimentation for the YPVS servo engine.
Messagede Rony le 10 Fév 2011 19:36
Hello.
Why do you want to pluy this cdi ? :-k
You know, you can try a 125 RDLC's cdi, phifi told me that the curve is a little bit better at the end between 7500-8000 to 10000rpm. :wink:
:idea: Or if you want, you can buy a programmable cdi, look at it.
viewtopic.php?f=26&t=15172
Messagede yamahaexpert le 10 Fév 2011 21:27
So Phifi, the green plug from Cdi will be with no function ? I know the plug with Brown and Black wires in wiring harness is a 12 V power source, so my initial doubt was if the cdi sould be connected to there or if would be the Ypvs servo, but it is the servo engine. right :?:
There is another component that i would like to know if can be also fitted to DTR wiring harness. I guess that it is for neutral and sidestand switch and for oil tank light . Should i also connect it :?: :-k
Here it is :
yamahaexpert
Messagede yamahaexpert le 10 Fév 2011 21:37
Rony a écrit:Hello.
Well Rony, actually this is for i try to help a friend of mine as he bought a 2RH cdi for a cheaper price and wants to fit in your DTR, however i would like to confirm how to plug it correctly to prevent any danger on cdi . RD 125 LC cdi is more difficult to find out used as it's a very rare here, so TZR is the best solution. I also know Ignitech programmable cdi, is the best solution at all, but in moment he doesn't want to spend much money :wink:
yamahaexpert
Messagede Rony le 10 Fév 2011 21:47
All right ! Sorry, I thought you wanted to change your cdi, because the curse is better than the origin one. :wink:
Messagede phifi le 10 Fév 2011 22:24
:arrow: You have no exit to the stator on the DTR to connect the green plug.
Even unplugged the cdi Noral work.
:arrow:
In fact it manages these functions.
DTR on this is handled by the CDI (blue and light blue).
It will probably plug it in, but I do not know how.
Messagede Titine le 11 Fév 2011 0:46
#-o :lol:
and =D<
Messagede yamahaexpert le 11 Fév 2011 19:04
Rony a écrit:All right ! Sorry, I thought you wanted to change your cdi, because the curse is better than the origin one. :wink:
Yeah i know Rony, Tzr has a better map than Dtr cdi. He just want to change it cause the original has been broken :|
yamahaexpert
Messagede yamahaexpert le 11 Fév 2011 19:08
phifi a écrit::arrow: You have no exit to the stator on the DTR to connect the green plug.
So, the green plug will be with no function. Do you have any picture from 2RL / 2RH generator ?
yamahaexpert
Messagede Rony le 11 Fév 2011 19:18
Hi.
Here's a picture of my tzr 2rl engine, you can see the connector from the generator.
Above it, there's the sensor connector. :wink:
My engine is out of the deltabox, because i'm restauring it. If you need some other picture, ask me. ;)
