Thank you very much for your help
ferrarinero a écrit:J'vais regarder ça(dsl on est en france donc j'écris en français)
Rony a écrit:Hello.
Why do you want to pluy this cdi ?![]()
You know, you can try a 125 RDLC's cdi, phifi told me that the curve is a little bit better at the end between 7500-8000 to 10000rpm.![]()
Or if you want, you can buy a programmable cdi, look at it.
viewtopic.php?f=26&t=15172
There is another component that i would like to know if can be also fitted to DTR wiring harness. I guess that it is for neutral and sidestand switch and for oil tank light . Should i also connect it
Rony a écrit:All right ! Sorry, I thought you wanted to change your cdi, because the curse is better than the origin one.
phifi a écrit::arrow: You have no exit to the stator on the DTR to connect the green plug.
Even unplugged the cdi Noral work.
