TDR problem with CDI Module 4FU[speed limit]
Messagede cinek100 le 11 Avr 2017 1:28
Hello.My Yamaha TDR 2002 is restricted with module 4GX - 01 0ZD.I repleced it with another module which look the same, but its name 4FU 65.. [on picture], and It's not much difference - RPM max 10 000 on neutral gear.Max speed 80 km/h and 7000 -7500 RPM.Compression is ok.Do you have any clue about 4FU module series?Is it unrestricted?Then maybe problem is YPVS valve or Exhaust?Or I need another module?TDR oryginally is from Austria.I appreciate any help.Salute.
cinek100
Re: TDR problem with CDI Module 4FU[speed limit]
Messagede phifi le 11 Avr 2017 8:25
It's impossible to mount a cdi 4fu on a tdr of 2002, it is absolutely necessary a cdi 5ae.
French's cdi are derestricted.
Messagede cinek100 le 11 Avr 2017 10:38
If I need 5AE , so how to connect to my connectors.4FU fit to my electric wires, but is restricted.5AE is derestricted but connectors and wires are diffrent and doesnt fit in :{
cinek100
Messagede phifi le 11 Avr 2017 13:26
In france, all cdi are derestricted (4FU and 5AE).
For us: 4FU 93/96, 5AE 97/03.
Messagede cinek100 le 11 Avr 2017 13:36
Then why my 4FU [if all are french cdi] is blocked at 10 000 RPM? #-o
cinek100
Messagede phifi le 11 Avr 2017 13:56
exhaust restricted ??
Messagede TOMTOM le 11 Avr 2017 22:01
il n'y avait pas a un moment une bride derrière le compteur avec un genre de bilame qui bloquait a partir de 70/80 justement? sur les modèles allemands il me semble.... Allemagne, Pologne.... why not !
http://www.dt125.de/dt125/Mainpage/Werkstatt/index.html
Messagede phifi le 12 Avr 2017 0:25
C'était le cas pour les DTR, mais pour les TDR je ne sais pas du tout.
Messagede cinek100 le 12 Avr 2017 2:48
phifi a écrit:exhaust restricted ??
I dont know is it restricted, but I disconnect exhaust totally and not better;[ There are 2 posibilities i think: CDI is restricted or there is other electric problem.
cinek100
Messagede phifi le 12 Avr 2017 9:28
:arrow: In France the TDR pots are restricted at the red line:
:arrow: In your model, the restrictions can be at:
Exhaust pipe
Powervalve
Cdi (switch in the tachometer)
:arrow: In the german model's the original CDI has an output of 5 volts, this one goes to the counter by the white / green, and there is a reed switch in the tachometer.
When you start the engine of the bike, the counter restarts from the +5 volts to the motor valve through the green / black.
If you have this white / green wire coming to the speedometer: you can cut it, or put a switch.[/quote]
Messagede cinek100 le 14 Avr 2017 1:44
Pictures:
https://zapodaj.net/c5a81e5136a83.jpg.html
https://zapodaj.net/afb7f721aa5d1.jpg.html
https://zapodaj.net/7f61a337cdb02.jpg.html
And maybe problem is carburetor/mikuni blocked?
cinek100
Messagede phifi le 14 Avr 2017 14:17
In the first picture the powervalve is closed !!
Messagede cinek100 le 14 Avr 2017 17:15
It is the state when powerwalve do the check and stops on the mark.So YPVS needs to regulate?Thank You phifi for infos.I'm going to reconect black/blue wire and earth.I'm not sure if this help for my module, but i'll try.
http://www.fotosik.pl/zdjecie/usun/3Inb0SI3dQOWWuWnEBLVj5~_HnSGf3
cinek100
Messagede phifi le 14 Avr 2017 17:30
Ok: the powervale is restricted !!
Messagede cinek100 le 15 Avr 2017 23:13
TDR before restricted exhaust and powerwalve:
After:
cinek100
