TDR problem with CDI Module 4FU[speed limit]
Re: TDR problem with CDI Module 4FU[speed limit]
Messagede cinek100 le 30 Avr 2017 12:49
I received TDR .Mechanic riped off original silencer.Max speed is 110 km/h now, but acceleration and RPM is not working smoothly over 7.5 000 RPM and little choke, max is 9.5 000 while ride[before was 10.500 and not choke].The jets are the same like before 270 and 25 originally. I'm consider about adjust idle carbureter to different set.That idle on film 1:37 sec.How high or how low should be this "ring" which block idle on certain position?
cinek100
Messagede cinek100 le 02 Mai 2017 12:53
Max speed is still 110 km/h on 9.500.I don't know what difference is between my TDR and fully unrestricted TDRs.
1.Tires are typical:
Front 100/90 18''
Rear 130/80 17''
2.Sprocket :
16x57
3.Geatrs ratio:
Primary reduction 3.227
Secondary reduction 3,56
1 gear 2,83
2 gear 1,88
3 gear 1,41
4 gear 1,14
5 gear 0,96
6 gear 0,82
Is there other explanation beside speedometer or tachometer shows false results ?
Not measures with GPS yet.
I found interesting application http://www.gearingcommander.com
cinek100
Messagede phifi le 02 Mai 2017 13:46
French models TZR and DTR/TDR derestricted:
Messagede cinek100 le 02 Mai 2017 17:40
And this thing inside airbox is normal for french bikes or unnecessary?
cinek100
Messagede phifi le 02 Mai 2017 19:28
normal
Messagede cinek100 le 03 Mai 2017 17:58
Ok , and what about this? it has any influance for adjustment ? There is no screw.
cinek100
Messagede phifi le 03 Mai 2017 18:31
This is for adjusting the richness
viewtopic.php?f=26&t=12328
Messagede cinek100 le 05 Mai 2017 0:28
What is this ?
cinek100
Messagede Phillip93 le 05 Mai 2017 0:32
I am not 100% sure but it looks a lot like a winker relay.
Phillip93
Snawboolisé
Messagede cinek100 le 05 Mai 2017 13:15
You're right it's for blinker.
cinek100
Messagede cinek100 le 13 Juil 2017 4:45
Hi again after long absence.The TDR max is now 115 km /h on 9500 RPM.I have one question: Can be that pipe admission is restricted ? I found two different types
Image Image
cinek100
Messagede phifi le 13 Juil 2017 16:47
Not restricted, but it can be modified like this: tutos/bacetpipe.pdf
115 km /h on 9500 RPM :shock:
This is impossible with the original transmission (16 x 57) !! Really the maximum speed is 125km/h for 9500 rpm
Messagede cinek100 le 13 Juil 2017 22:32
Yes I have original 16/57 sprockets , original tires and gearbox transmission also.The question is what takes the 10 km'/h.My tdr was originally restricted to 80 km/h not like other versions to 90 km /h.
And second thing:I can understand these two modifications, but third dont.
"Pour terminer, on peut aussi supprimer le boitier YEIS qui vient se fixer sur la pipe, son rôle est de favoriser
les reprises à très bas régimes mais au détriment d'une bonne accélération.
Pour cela il faut enlever ce boitier et boucher le trou de la pipe avec un cache maison, la reprise sera plus
franche mais le réglage carburateur un peu plus délicat, on obtient alors ceci"
Is it worth to remove this box and block the house if its written that the recovery at very low revs wil be better but at the expense of a good acceleration.Mayby it subjective and depends on person for who it is better?
cinek100
Messagede cinek100 le 20 Juil 2017 20:55
phifi a écrit:Not restricted, but it can be modified like this: tutos/bacetpipe.pdf
You were right phifi.Yesterday iI used GPS device and it show 125 km/h max at 9500 RPM.The speedo show 10 km/h less than real speed.But I dont know why it doesnt work properly.
cinek100
Messagede Phillip93 le 27 Juil 2017 10:05
Usually, I understood that speedos tend to overestimate your speed and not the opposite....are all speedo parts original? A different tyre size? A shitty cable or worn drive maybe?
Getting back to the YEIS thingy, you could try removing it to see for yourself how the bike goes and if it suits your riding.... :wink:
Phillip93
Snawboolisé
Utilisateurs parcourant ce forum: Google [Bot] et 34 invités
